Rapid Robert
what are the best ones that fit & flow the best? thank you for your time. RR
that is some good info. I milled my early 2&1/4 outlet ex manifolds 1/4" & it barely clears on the pass side & alot of room on the drivers side tho this is the 63 dart stock car with the racing thin steering shaft & this is with 3/8" of spacers on each motor mount but now that I have milled them I am going to see if I can remove em. On a side note I thought the 68-70 340 pass side ex manifold was way wider (maybe I'm wrong on that) than the pass magnum but a moot point cuz I am good right now. I do have a 408 stroker in the works & I'd like to use another set of magnum manifolds when the time comes in an early A bodyHere is one thread with some pictures. Search is your friend.
340 Exhaust Manifolds on Early A-Body??
I have the aftermarket copies of the 68-71 340 manifolds in my 66 Dart with a 360. As RustyRatRod said they are good but your fitment may vary. I am running TTI 2.5 inch manifold back exhaust (a challenge but I made this work). 90 degree oil filter and smaller filter is a must.
The manifolds are available on eBay.
If automatic Sanderson dd9 all good.I've heard some glowing reports on Dougs & alot of bad on TTI's & yes the 273 logs would suffocate it. I do have some Hooker 5208's but since this 408 is going to be a mild daily driver I will try like Hell to get some magnums to fit. thank guys. RR
lolI believe there is a set for sale listed in mechanical parts for sale.![]()
I had a 68 340 and its logs in my high school 65. No issue, A/T and no power steering. I got big magnums for my 408 build...and 2 sets of headers.
