MOPAR_MAN619
Active Member
- Joined
- Jul 3, 2008
- Messages
- 35
- Reaction score
- 70
True! The gears on a spool is good coin but an entire trans is gonna suck.Wow! I know rear ends are expensive, but at least it wasn't the motor what let go!
it had a spragMy guess Pinion depth to deep. A bolt in sprag could have saved the trans.
you're right about that ! that would've sucked having to put another motor togetherWow! I know rear ends are expensive, but at least it wasn't the motor what let go!
The sprag looks like it ripped out of the splines in the case. Did it shear the bolts I don't see them?it had a sprag
