66dartman
I rebuilt the 440 from my co-worker's 71 Chally with a new crank, H beam rods, KB pistons, etc. I bought a Comp XE 268H cam & lifters for it. Block was not decked and the heads are out of the box eddy's. I installed the cam straight up. put the engine back in the car, no compression. comp says stock pushrods too long, but I don't see how since nothing was changed. Deck height and heads are the same as before. Pulled it back out after much talk with Comp techs. Any ideas? I am going to try a hughes cam. Checked timing marks several times, tried to get the cam to the 106 int. centerline but found it to be 27" off. comp says I'm full of it.
