451 Indy Motor
dan69rr
Active Member
melrose fl
Time to sell the motor: here what I got:
1971 RB 440 block
Wiseco pistons flat top .055 over, .990 pin
Callie (hemi crank 4340 material, mains 2.750,rod journals 2.375
Main caps (Aluminum w/arp studs
Eagle rods 3-D H- beams 6.760 w/.990 pin
Indy 440-1 cnc 345,Indy intake(6.750 tall) Indy Valley cover,
Indy Valve cover
Manley Valves Int.2.250, w-11/32 stems, Exh. 1.810 w-11/32 stems
Manley Valve Springs- 10 degree keepers,titanium retainers
double springs.
Jessel roller rockers; 1:55 ratio
Jessel solid lifters
Milodon Gear drive w/adjustable bolt pattern cam gear
Milodon 7qt, panw/single hole external oiling
Milodon external pump
Comp Cam 690 lift 323 duration @50 w/ 108 centerline
the motor has been blue printed, balanced, line bored, deck for flatness, and cross deck plate for straightness
the bore is .055 over yielding 451 ci
the motor will make over 800hp, asking price $11,000.00
any questions please pm me, thanks for viewing, Dan
just kind of curious, will this thing really produce 800 plus HP, i haven't seen an 451 make this kind of power on an DYNO yet!!!!!!! anybody else NO, sounds like a killer motor though!!!!!!!!!!
Nice looking engine. Is it new or used?
If it does make 800+, big if, its going to be way up there in rpm. My guess would be 8000rpm or more.
Hi Dan, I haven't heard from you in a while? I've bought parts off Dan before, great guy no problem. Back when I last talked to him the engine was all new never ran.
Hey Mike, Thanks for the question. It is new, and for the performance of the motor the rpm range will be in the high 7000, this combo was factored with the solid bottom end, pistons,rods,cam, and the porting, valves the Indy head produce. Larry Ziglsis retired crew chief of Army in the late sixties and Frank Danston who runs this same combo in his 70 cuda , yielded 834hp and 779 lbs of torque. A great torque monster, thanks Dan
