dan69rr
Active Member
Time to sell the motor: here what I got:
1971 RB 440 block
Wiseco pistons flat top .055 over, .990 pin
Callie (hemi crank 4340 material, mains 2.750,rod journals 2.375
Main caps (Aluminum w/arp studs
Eagle rods 3-D H- beams 6.760 w/.990 pin
Indy 440-1 cnc 345,Indy intake(6.750 tall) Indy Valley cover,
Indy Valve cover
Manley Valves Int.2.250, w-11/32 stems, Exh. 1.810 w-11/32 stems
Manley Valve Springs- 10 degree keepers,titanium retainers
double springs.
Jessel roller rockers; 1:55 ratio
Jessel solid lifters
Milodon Gear drive w/adjustable bolt pattern cam gear
Milodon 7qt, panw/single hole external oiling
Milodon external pump
Comp Cam 690 lift 323 duration @50 w/ 108 centerline
the motor has been blue printed, balanced, line bored, deck for flatness, and cross deck plate for straightness
the bore is .055 over yielding 451 ci
the motor will make over 800hp, asking price $11,000.00
any questions please pm me, thanks for viewing, Dan
1971 RB 440 block
Indy Valve cover
double springs.
