mopops
5.2 motor decked to 9.1 comp and 302 heads - whats a good cam to run?
This is the critical question..... the cam to use will vary all over the map depending on the application. Anything the OP can say to let everyone know the engine use will help him get better answers.Depends on what you want to do with it.
Ditto without a doubt. Hit'em hard! Beat the competition with a bigger stick, shove it down there throat and out there keister!.750 solid roller.
.750 solid roller.
