5.9 Magnum Question
Discussion in 'Small Block Mopar Engine' started by mopardug, Jan 10, 2017.
  1. mopardug
    mopardug FABO Gold Member FABO Gold Member
    107
    10
    Sep 14, 2012
    Central KY
    Local Time:
    6:59 AM
    I have another stupid question lol. Sometime in the past I was told that either '99 or 2000 5.9's were different from the earlier years. Something about the crank snout or maybe the balancer was different and earlier (common) parts wouldn't work. The person also told me that those newer 5.9's weren't worth having. The engine in question was out of a '00 1ton van. Is this another case of a mental midget? Or is there something to this? P.S. I went back an even 13 pages and didn't notice a topic like this. Thanks for looking.
  2. Lelo Dart
    Lelo Dart *
    1,126
    204
    Oct 10, 2012
    Knob Noster MO.
    Local Time:
    5:59 AM
  3. rumblefish360
    rumblefish360 so close yet so far away
    29,551
    2554
    Jun 21, 2005
    New York, on a Island
    View My Photos
    Local Time:
    6:59 AM
    Yes, mental midget-ism.
    Some do not like the pedestal mount rockers and cringe that a Chevy rocker can be used. The port flow on the Magnum head is an argumentative point on "Is it better than an LA head?"
    Earlier Magnum engines?
    I guess it all depends on what you want to do, what cost is involved for your wallet and what your willing to live with.
    There are pro's and con's to each engine family. A, LA, Magnum. I'm making use of a '00 , 5.9 in my '79 B body. With the serpentine belt. No fuel pump eccentric so I used a Edelbrock electric carb pump. A B&M flexplate to mate it up with a neutral converter & 727, RPM-AG, AVS Thunder 650 & Super Comps. No cam yet. 3.55's out back.
    Works great for me!
  4. Abodybomber
    Abodybomber Breaking street machines , since 1983.....:)
    29,305
    7775
    May 21, 2011
    Arroyo grande ca
    Local Time:
    3:59 AM
    I was handed a 2000 Magnum,for free... even the service replacement heads,were toast,the roller cam,had three flat lobes...Ended up with EQ heads,the Crane cams,stud set up, and 1.5 Comp Cams Chev rockers...I like valvetrain adjustability,on my stuff...
  5. 73AbodEE
    73AbodEE I'm hungry
    15,167
    1183
    Oct 16, 2011
    Down the road
    Local Time:
    5:59 AM
    Tim , how does a roller lifter eat a cam, no oil ? High miles?
  6. Abodybomber
    29,305
    7775
    May 21, 2011
    Arroyo grande ca
    Local Time:
    3:59 AM
    Lance,higher mileage...cast iron core..196 k on mine,still had crossshatch on bores....
    • Thanks! Thanks! x 1
    • TrailBeast
      TrailBeast Slightly Twisted Member
      17,129
      3332
      Mar 11, 2011
      Arizona
      View My Photos
      Local Time:
      4:59 AM
      Did about the same as Abodybomber.
      Mine had about 90k on it and cylinders and bearings, looked near new but the heads were cracked on all four corner cylinders right between the valves.
      EQ heads, Hughes springs and retainers, stock magnum rocker gear on mine, custom regrind LA style roller cam with a Carter rotary vane pump and full circulating fuel system.
      The Magnum has a great bottom end that lasts a long time, but the heads are the weak point in them.
      The relatively inexpensive EQ Magnum heads solve that problem and flow well right out of the box. (about 230cfm)
    • gtsdude
      gtsdude Well-Known Member
      719
      105
      Jan 10, 2010
      SE MN
      Local Time:
      5:59 AM
      I believe 99 or 2000, not sure when they made the switch, but the balancer and crank pulley are one piece on the newer ones and older ones have a crank pulley that bolts on to the balancer. Not a big deal if you are using the serpentine set up. If switching to LA front and pulleys just need an older style balancer. Other than the balancer not much changed.
    • mopardug
      107
      10
      Sep 14, 2012
      Central KY
      Local Time:
      6:59 AM
      Thanks everyone! And Lelo, that article was very informative.
