Guys,
Good morning. '72 Duster with a 318/904 right now, with a 8-1/4 rear end. Was planning to go big block as the heads seem to flow better for something around 400ci. I seem to be getting mission creep...
Got a '78 440 complete in a trade, needs machining work and assembly.
Purchased 440source.com heads and rockers for $1000 a month ago.
Same engine the heads came off, have the option to purchase the short block. Is a running 512 all assembled ready to go for $2500. Cam is a .510 lift, owner is e-mailing the rest of the specs, but was the largest the stock springs could take.
This seems to good of a deal to walk away from.
1) Is this going to be streetable?
2) I have a large aluminum radiator now, any issues with cooling?
3) what is the estimated HP?
3a) Need to upgrade rear end someday
4) I know I need sub frame connectors, my uncle says I may need a roll bar now to keep the chassis stable, is this needed as well?
Essentially looking for any input from owners of 440 or larger that drive them on the street.
Thanks!
Thanks!
