69_340_GTS
750 cfm isn't "too big" for a 360 engine. That's my simple answer, based on about 45 years of experience. Heck, the stock carb on a 340 was around 800 cfm.
Got the Scamp back at noon today from the exhaust shop. It sounds GREAT. It feels snappier / peppier. As to be expected.
Now the carburetion tuning begins. I've been reading the Edelbrock manual. The manual is very well written and it sounds like a cinch to adjust. I also purchased an AEM wideband and had bungs installed in the exhaust. So, I am going to try to get the wideband installed this weekend. It will make knowing which way to tune a breeze.
Here's a cool calculator that may help in tuning. Pair this with a wideband A/F gauge and it will guide which way to go as far as jets and rods.
302w.com - Edelbrock Carburetor Jet/Rod Fueling Calculator
So you drove over to Summit and got it, cool!
If you don't have to change jets, you can test several combinations in one outing. Takes seconds to change rods and springs once you get the hang of it.
Cross reference the different model's venturi, jets and rods, do a little math, and you will find you can do a lot more than the dots shown. I didn't have an AFR meter, but I had fun messing with mine.
Good luck!
As for my bullets above:
- I'm going with 1 thin gasket, unless I seem to run into heat problems. I will hang onto that big thick gasket in case.
- I actually moved it back to ported advance because I didn't understand why manifold advance threw off my idle. Late last night I read about it. And now that I understand the difference between the 2, I'm going back to manifold advance and will reset my idle, and idle AFR.
Last night: After changing to the leaner metering rod, it was even richer! So while driving, I was thinking that it was "as if" the 5" spring was lifting the metering rod out of the main jet too easily, and going rich. So I went home and put in the blue 3" (lightest) springs so that the vacuum can more easily hold that rod down in the main jet. Then I drove it again. That made a difference. It was definitely leaner after the spring change. But not nearly lean enough.
- I drove with the gasket as mentioned above, seemingly no issues. It's the same gasket overhang as before, and it is the gasket that came with the carb, so I'm just going to forget about it.
Tonight I'm going to change to manifold vacuum. Don't know if I will get to drive it though. But my theory is that in cruise mode, there should be more timing. The additional timing would help burn the fuel more completely. My theory tells me running manifold vacuum will also drive it toward the lean side. So, before I change rods again, or jets, I need to test it on manifold vacuum.
Wrote all the above earlier. Now it's late. I did change to manifold vacuum. It seemed to have no affect on cuise AFR. Still very rich. Power mode seems close.
I tuned the idle to be 13.5 - 14.0. But that seems too lean. It seems very lopey. Alright at idle but when I put it in gear it seems to almost want to stall. Edelbrock suggests 13.0 at idle so I will tune for that. And go another step leaner for cruise mode.
7milesout
(Doing the hand over head thing here). Whew! You went over my head with all that. I don't think I will (or can) change air bleeds on an Edelbrock.You're doing well. Pretty soon you'll be tuning Holleys like you been doing it all your life.
The metering rods are kind of like the power valve. The springs you swapped are like the opening point of the power valve. The power valve channel restricters are the same as th small end of the metering Rod. A jet is a jet.
It's easier to change emulsion and air bleeds on a Holley.
See, your almost there. Keep it up.
