doc540
paging SlantSixDan
Since I determined my block is a '68, should I pull the plugs and tubes and remove all the washers from the new set of plugs?
Gap remain the same if I remove the washers?
Thanks!
btw: no tube leaks after replacing all the rubber rings
Thanks!
