Hello gentlemen! In the past I've really only ever used this forum for questions. Just wanted to share a few pictures and information of my build.
I bought this car almost a year ago, has a pre magnum hydraulic roller 318 with the 302 heads. Motor is stock just has summit headers a torker 340 intake msd ignition and a holley stealth efi kit. Behind that is a 727 with an 8 3/4 rear motor & transmission I pulled out of a 84 d100, rear came out of a 71 duster I use to own. Has qa1 k and upper lower control arms pirate jack disc brakes up front. New brake lines with a master cylinder from a company called inline I believe. Has a tanks Inc fuel tank with the fuel pump in it for efi, new fuel lines that came with my 71 duster. Rear disc brakes are a cheap speedway kit, have some engine wiring from h&m or m&h whatever the company is called is some quality stuff. Wheels are 17 Boyd Coddington wheels that I found on market place. I'm sure there's stuff I'm missing out getting close to running got some wiring that needs installed and other minor stuff, now that this Texas heat is going away I'm jumping back on it.
