fishy68
Tyr Fryr's Inc.
A buddy of mine bought a 750 Holley double pumper HP series list #82751 from a guy used but like new and the guy was pretty car dumb because he bought it for his stock 75 Monte Carlo 350. Well needless to say it was way too much. So my bud got it at a decent price. Well it got here and looks nice. Terry don't have his engine together yet and asked me to put it on my engine and see how it runs. I put it on and set the floats and fired it up and warmed it up and set the idle. All went fine up to this point. Well when I accellerate it falls flat on it's face Under light, med., or full throttle. So I checked the accellerator pumps. Their real lazy. WTH. I pull the front squirter out and see there's no check ball/needle under it. Pull the rear squirter. Same thing. Either the original owner took it apart and lost the needles or Holley forgot to put them in. I pulled the bowls to see what jets are in it and what PV is in it. Has a 5.5 inch valve and 75 jets in front and 82's in the rear. Can't find any info on Holley's sight on this perticular carb. Anyone here run one that knows what the stock jets are? I'd like to know a baseline since this one may have been altered. Seems the seller won't answer Terry back to tell us if he changed the jets and if so what the originals were. Probably cause he knew the carb. was screwed up.
Thanks and sorry about the novel. Tracy
