darc1722
I have a speedo drive gear on my 904 transmission that is not spinning the cable I think it's not set correctly as the hold down bracket was loose. (I also verifid the speedometer is working by using a drill on the cable.) Do I need to drain the transmission fluid to work on this or can I adust it without removing it. I can rotate the assembly and there looks like there's three possible positions but I don't want to strip the gears. Anyone dealt with this before? What's the correct way to set this without damaging the gears? Thanks
