chickendeluxe
I have both in usable condition.
Before I pull them out I have a couple Q's....
Are the OD units about the same size and are Trans mounts in same place if I ever change out trans?
A friend told me there is trouble with the conventional Console Shift.
What have you guys done regarding the bracket that bolts through a 904 or 727 holding the
Shifter Bell crank pivot?
Thanks in advance
Thanks in advance
