67Dart273
...........You.........got..........er.............LOL
What these do, is, diodes act sort of like a "check valve" for liquids, that is, they only flow current in one direction. But WHEN they are "flowing," which is known as "forward biased," diodes all have SOME (tiny) amount of voltage drop, which can change with the type and rating of the diode, as well as the current going through it.
So this tiny voltage drop allows some current to "shunt" in parallel with the ammeter, but some goes through the diode.
The reason you need TWO is that when the alternator is charging, one diode is conducting, but if you , say, example, are parked, and are using a load (stereo) off the battery, then the OTHER diode will be conducting.
