stroked340
You'd be better off to ignore anything that Jack wheel says...
Says the guy with the "junkyard" jalopy..
I agree with that I actually thought about doing this. I have an extra set of steel wheels I just dont know how affordable 14 inch drag tires would be. If they are available at all?What size street tires do you have? I do like the idea of getting some used rims and maybe even some used slicks. Possibly a little smaller diameter than your street tires to add to your gearing.
I suggest this because it's what I did at the beginning and it dropped my quarter mile time by 1/2 second the first time I used some used slicks and some cheap steel rims I got from the scrap yard.
The man that introduced me to drag racing 20 years ago was a literal "junkyard" man he live in and ran a junkyard he had junkyard full of abodys and he raced abodys. He had a 75 dart hand 10 gear jammer that he build out of junkyard parts. Nothing wrong with that not everyone has 20 grand to drop on a racecar. I'm willing to bet that junkyard dart was faster than most prestine 20k bought cars!Says the guy with the "junkyard" jalopy..
Tune first then gears (if the lowest et possible is the goal) from the looks of his car it's a street car car. 3.91 is not a good gear with a 904 in a street carBecause the guy that stated it has a (friends dart) with a "smog 318" stock 360 heads small cam and 3.91's running 13.70's but then I know how to tune...
Quicker than mine? Yes mine dont run Haha.And quicker then some of the others commenting here too..
What size tire?Friends dart is a "street car" drives it on the street/highway all the time..
What size tire?
I just watched Craigslist till some something popped up. I just sold my drag slicks and skinnies at the swap meet for half of what I paid for them, but I haven't used them in 2 years and didn't plan on Switching tires back and forth again. I didn't mind when I first started though and when I was drag racing more seriously...I agree with that I actually thought about doing this. I have an extra set of steel wheels I just dont know how affordable 14 inch drag tires would be. If they are available at all?
I agreed with the junkyard jalopy when you're talking about my car. I built it myself. Rebuild everything I can myself suspension transmission and anything I can do. And I certainly know how to put on two bolts on a thermostat housing the first time..Says the guy with the "junkyard" jalopy..
That's a 16.23 1/4 mile..get your self some drag radials and a set of 3.91's and you'll go a lot quicker..
Where would you start? Timing and jetting?Guys, it's really 2 parts. MPH and ET.
Bad traction or a bad 60 ft will effect the ET, but not a hole lot on the mph. 3.23's with traction is plenty of gearing for a mild 360 with headers to get maybe 78-80 mph in the 1/8. In fact, without headers and 2.45's I got 78 mph in the 1/8. The real story is the OP got 68 mph, with 3.23's and headers, two things I didn't have. That is why I say the car should run at least 80 mph in the 1/8, which with tractions would equal at least mid 8's in the 1/8.
It's that simple.
I dont know that story lol. Arent all intermediate shafts hardened?...and don't forget the hardened intermediate shaft! oh that's right! You did forget it!
Poo! That sucks. I hate finding out the hard way! Lol are original ones hardened? I have 3 factory ones 2 from 318s and one from a 360!No and he found out the hard way.
Honestly, if the car was at my house, this is the order I'd start. And go as far as needed to get the ship corrected..... lolWhere would you start? Timing and jetting?
Cool good to know!! ThanksNo. The hardened shafts are for use with HV oil pumps.
A/F ratio gage if your looking for a reading. Reading plugs is more difficult with todays gas, but can still be looked at. I pay attention to exhaust, smell, hearing, clean idle, full pull at WOT, be sensitive to flat spots in the "slow progression of the acceleration".So carb adjustments are just kind of make an adjustment and test it out? Other than plugs are there any tell tell signs of lean or rich?
I do not run a gauge. 12-14 ratio. Again, the car will let you know what it needs or wants. Some get caught up in the "perfect reading" on their A/F gauge, and suffer.What is the optimal a/f ratio or does it depend?
Do you run a gauge?
