Well j par got me thinking about the clutch. In my original post I did mention that I was trying to "clear it up" ......stomped it and smacked 2nd.....that's when it started.
After a rough day fighting the 99 scattersheild bolts, the headers and other stuff , I found a damaged pressure plate. As you can see below, one of the struts took a major hit and bent badly.
After doing some measuring with calipers, it looks like although the p plate shell was still bolted on center, the heavy friction disc was pulled about 284 thou off center . Over a quarter inch off balance.
I'm not 100 percent certain but pretty sure I solved it.
McLeod SUPPOSEDLY put this set up together for my combo. Less than 20 miles on it.
View attachment 1715169984 View attachment 1715169985 View attachment 1715169986
So thanks to all who helped out and kudos to ole j par for getting my brain in the right direction!
