Many many ways to approach that problem
No particular order:
1...Can the seller provide you with the "ends" that fit the box so you can have your own made?
2...Some hydraulic hose shops can make ps hoses depending on the ends
3...Do you have any hoses "with good ends" which fit your pump? Hydraulic shops have ends that clamp to the cut--off ends, a form of compression fitting
I still remember this part no. from the eighties....my parts store days.........Weatherhead 06U-755 or 756 for 5/16 or 3/8 tube
This particular one fits common double braid hydraulic hose
Yet another way to get an existing hose end "reused" is to silver braze the bent end into a JIC flare fitting, which you can then connect to a JIC hose end crimped to the hose.
4...Parts store hoses in some brands come in three pieces.....a bent end for the box, a connecting hose, and a bent end for the pump end. If you find a cooperative parts store guy AND A PICTORIAL GUIDE you can "mix match" ends
