Latest cam recommendation from Hughes. I'm changing direction. This one is a hydraulic roller...I wish it listed the advertised duration.
This is a long snout cam. It works fine in the 93-03 Magnum engine but you will need to use our HUG7011 Cam bolt & washer and the HUG7542 cam key (see below in Related Parts).
Hydraulic roller small block camshaft.
Basic guidelines (These are not absolutes, just guidelines to help you get close on a cam choice)
Use: Serious Street or mostly Strip, works well with aftermarket heads and high flow throttle body/carb, upgraded injectors a/r
Idle: Noticeable
Vacuum: low to mid
Converter: 3200+ stall
Rear gear: 3.55 +
Benefits:510+HP potentiel at flywheel
Requires a computer upgrade (like a tuner)
