coffeedart67
Got the replacement cam from my engine builder, first cam had .536 lift, this cam has .468 lift. Here is the comp cams page on it.
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=665&sb=2
The engine is stock rebuilt, bored .030, stock heads rebuilt, stock everything. Auto tranny with stock convertor, 2.67 rear gears(I think, or somewhere around there), 2 barrel intake with stock carb. Would like to find a STOCK solid cam but haven't had much luck. One auto parts said they used to be able to get them, but they recently rebuilt a 66 273 and had to have Comp Cams do a custom grind. If I go with a custom grind will they have all of the specs, because all I have been able to find is in a direct connection book stating that the 2 barrel 273s had a .400 lift sold cam(up to mid year 67).
Thanks
Coffee
Thanks
Coffee
