Bores not brush ed but this is the reply I was looking for... now I know at least where to start.... thanks friend....If it's walking you'll be tearing up the distributor gear, and either scaring your timing cover or the thrust face of the block. You probably won't hear it regardless. Did you have the lifter bores bushed?
On what? What kinda cam? What kinda cam hardware? Conventional timing chain, belt or what?
How in hell are we supposed to know what YOU have unless you tell us? The cats knocked my crystal ball off the table and broke it.
Throw us some bones here if you want some help. Otherwise, you might as well have asked, "what's wrong with my car......it's blue?"
Put a custom roller cam in a roller LA with ur typical timing chain. Push rods are the correct length.... I would imagine a cam walk sounds the same whether it’s belt, chain or otherwise.... almost sounds like a rod knock but goes away with RPM
That’s what I was thinking. The cam should not be walking anywhere and if it is, you have loose bolts on the cam retainer plate.How do you have cam walk with a small block Chrysler? It has a cam plate.
He said the knock went away with rpm.
Things like...
Piston rock and or skirt scuffed.
Sometimes the beginnings of a rod going...other times low oil pressure at idle in general leading to it.
No walk with a plate holding it
Oh that die cast thing from 1961?I just now figured out what your avatar is. You suck.
2 carbs on a custom intake, a little head work...someday.Yeah. lol
