sledger46
I am thinking I need to pull my stock 360 for a "freshening". I already have plans for a new cam, lifters, double roller timing chain, and mildly ported "J" heads. I will add those part to my existing M1 dual plane intake and 3310, 750 vac secondary Holley carb, and 1 5/8" long tube headers.
The 360 is a low compression LA engine from the late 70s with unknown miles and leaky gaskets. The leaky pan and rear main gaskets are the main motivator for pulling the motor.
Enough background, onto the REAL question: Would it be cheaper to offset grind the crank to get the stock pistons close to zero deck or buy new pistons and have the block bored?
I was originally thinking re-ring and re-bearing with a new oil pump, but might be willing to go a bit further if the price is right.
Your thoughts?
Your thoughts?
