china airgap intakes on ebay
Crosswind,....do a search on here and see what people have said about em.
Is this for a Magnum with a serpentine drive? If so, it won't work.
As long as your engine ain't a mag, let r rip. Make sure the intake runners line up.
When you get it check it over with a fine tooth comb. Some seem to be ok while others have crappy port alignment and the mating angles aren't correct. When you buy a cheap product expect a cheap product
Easy fellas.
The ad on eBay says that the manifold has been bolted to an engine for display purposes. Yeah right. I think it was probably bolted to an engine, it didn't seal right, and someone sent it back.
Just my two cents.
