I'm putting together another 408 this winter and have been looking at flow numbers and head options. Looks like the sad truth is that no production mopar head flows phenomenal numbers without extensive porting, polishing, and valve jobs. I originally figured i'd buy an assembled set of edelbrocks, and then have to spend 1k at a machine shop, and still need new springs. all this money and work to barely flirt with 300 cfm at .500 .600 or so lift.
BUT i call and talk to mopar, and the guy gives me a part number for a supposed, nearly drop on and go head. The commando head retains LA headers and intake, but internally is a completely different design with offset, huge valves, using a W2 style rocker.
the only problem is a complete lack of info on them. They are cast by edelbrock, designed by some ex chrysler race engineer who is no longer with the company.
i did find finally find the part number in a mopar cat, using a 2.055 valve (where as i see other large port commando head sources calling it a 2.1, 2.088, and others. however the flow numbers are all over the place, some as high as 310, some as low as 240. with only minor porting noted.
they DO use them with ZERO porting on the 440 commando smallblock and make 540-550 horse...seems to me that 240 cfm wouldn't get you there...
i guess my long post comes down to if anyone has used them? impressed with them? think some garage gasket matching could get those flow numbers to 300ish? mopar tells me even a edelbrock preformer can't touch the flow of the commando due to its valve redesign and internal structure. what do you guys think?
