Southernman
Guys, I have a complete 4 spd set up that I pulled from a running 68 340 Dart, which had a 500" BB and 727 installed. Therefore, I no longer need these parts.
Again, the car was running; it was a 340 4 spd car; had 3.91 gears and facdtory 14" rallys. Trans is a steel 23 spline unit.
These parts would be adequate to put a good running street car on the road, but if you plan to race it, or run with sticky tires, I'd probably replace the clutch and pressure plate, but they are usable as is.
I'll take $600 for everything:
Bell housing
Flywheel
Clutch and Pressure Plate
Throw out Bearing
Clutch release fork
Transmission
Shifter and linkage (it's an old Indy shifter that does work, but I'd find a Hurst and replace it if you desire "vigorous" gear changes.
I may also have the Z-bar that goes with it.
All parts are good. If interested, LMK your location and I'll see if I can come up with shipping fees. PM me if interested.
Southernman
Bell housing
Flywheel
Throw out Bearing
Clutch release fork
Transmission
Southernman
