midlife89
I'm finishing up my front end rebuild and have a couple ?'s.Should I jack lower control arms up to where ride height is going to be before I tighten down upper control arms,lower control arm nut and strut rod and then install torsion bars.2nd ?:Is there any particular position the lower control arm should be when i re install torsion bars? I have the torsion adjustment bolts backed out till rounded end is even with the bar it screws into,no threads showing.Tried searching this forum and checked the service manual but have seen no mention of it.I know on my fox body mustang you have to tighten lower control arm bolts when suspension is under load.Maybe I'm over thinking this but just want to make it's done right.
