72demon96 Well-Known Member Joined Nov 21, 2013 Messages 202 Reaction score 33 Location anna IL Feb 4, 2018 #1 Can you replace the door pin in the bottom door hinges I read some where you couldn't replace it thanks again
toolmanmike Moderator Staff member FABO Gold Member Joined Jan 18, 2006 Messages 84,245 Reaction score 95,075 Location Office Feb 4, 2018 #2 Good question. I don't believe I've seen one that needed replaced. I'll check out "search".
toolmanmike Moderator Staff member FABO Gold Member Joined Jan 18, 2006 Messages 84,245 Reaction score 95,075 Location Office Feb 4, 2018 #3 Post#2 which hinge pin repair kit?68 cuda Moparleo just bores the hole out for a oversized pin. MOPARLEO'S E-BODY REMANUFACTURED DOOR HINGES Here's a link to search function. You can sort through the threads to find your answer. Search Results for Query: hinge | For A Bodies Only Mopar Forum
72demon96 Well-Known Member Joined Nov 21, 2013 Messages 202 Reaction score 33 Location anna IL Feb 4, 2018 #4 Ok thanks
JeffisOld Old, Ugly and generally Disagreeable! Joined Jul 2, 2017 Messages 3,377 Reaction score 3,992 Location Sophia,NC Feb 4, 2018 #5 I'm gonna go out on a limb here and say that ANYTHING can be repaired. Since I have joined this forum I have seen things fixed that I would never have thought possible. A Cuda Grill panel I saw he other day amazed me. Not cheap, but amazng!
