buckshotbishop
Old Soul
just found that my free edelbrock 1406 has a nasty throttle shaft vacuum leak so its time to get a new carb. what do you all think i should go with a 650 or 750?
my set up
69 valiant about 3100 pounds street maybe a few passes at the strip and an auto-x day or two
340
crane hydraulic roller #699611
1400-5400 rpm
@.050 adv lift lsa
int 214 276 .488 112
exh 222 284 .509
J heads with 2.02 int and 1.6 exh no porting
will switch them for mildly ported aluminum heads when i can
rpm air gap
tti step headers
2.5 inch exhaust dumped at the axle
904 with hughes 2500 rpm converter
8 3/4 with open 3.23's
id also consider a holley if any one thinks there is one that would just be perfect for my set up
my set up
340
1400-5400 rpm
@.050 adv lift lsa
exh 222 284 .509
rpm air gap
tti step headers
