Engine / k frame dollie
easyrider
65 droptop
Crystal Springs, MS
Dos anyone have a picture or print with dimensions of the dollie that you can use to lower the k frame with engine and transmission out from the bottom of the car?
Tom
Made one out of spare 2x4's and 5 HF dolly wheels. Works great. I can try to get a better pic of it for you if u want.
I did the same thing with wheel dollies under a piece of 1 1/8 plywood tapered the cut to fit inside my engine hoist wheel frame. Secured the dollies to the plywood with 1x3 wood screwed into it. Motor tranny and headers installed. All stuff I had in the shop.took old motor and k out and put the new in by myself. Take your time and it's no problem.
I just used the el-cheapo harbor freight furniture dolly for 8 bucks. It held my 440/727...
did it the same way...2 furniture dolly's connected with 2 wooden beams...works perfect for my 318 incl. transmission, k-frame + suspension :thumbrig:
Thanks guys, i appreciate the low bucks approach, but i was hoping to see one made from square tubing that i could possibly start the engine on. If i find one, or build one, i'll post a pic of it. Thanks again,
Tom
