i hope i haven't missed it....but what is the actual temperature?
I ordered a temperature gauge on Ebay. As soon as I received it, I could check and see if my dashboard gauge has a problem or not.
Ok,thanks.The site does but you have to dig for it, it's in the help part. the ralley dash has a built in regulator in the gas gauge. They have a wayto work around it. Here it is .
RTE Limiter Faq - rte
The world may never know. LOL Sounds like the op has a gauge ordered. A temp gun or even a meat thermometer would help diagnose a heating problem. I won't even call it overheat. I don't think it did. Time will tell.i hope i haven't missed it....but what is the actual temperature?
I prefer test with a new gauge rather than a temp gun.The world may never know. LOL Sounds like the op has a gauge ordered. A temp gun or even a meat thermometer would help diagnose a heating problem. I won't even call it overheat. I don't think it did. Time will tell.
Me too and with a quality gauge. It depends whether you are diagnosing or monitoring.I prefer test with a new gauge rather than a temp gun.
And it wasn't overheating with either gauge.I had a 340 that wanted to run 205 no matter what.I was using a good Equinas gauge.Then i installed a good Stewart Warner gauge and it ran 190 from that point on!
Or.. You can just go down to the local auto store and buy a Mr Gasket Thermocap Radiator cap for $30US
I have read that the probe isn`t long enough on thse to be accurate, especially on rads. that like to run a little low .-???????????Or.. You can just go down to the local auto store and buy a Mr Gasket Thermocap Radiator cap for $30US
At least this will tell you what you radiator temp is before you...
The antifreeze needs to be 'topped off' so it can touch the probe. As to accuracy, I also installed a 'pro' temp gauge that the probe screwed right into the radiator, which I assume is the location for an electric fan probe. Both gauges were within about 5deg of each other.I have read that the probe isn`t long enough on thse to be accurate, especially on rads. that like to run a little low .-???????????
I`d buy one if the probe was longer, mine likes to run about 1 1/4" low for some reason !The antifreeze needs to be 'topped off' so it can touch the probe. As to accuracy, I also installed a 'pro' temp gauge that the probe screwed right into the radiator, which I assume is the location for an electric fan probe. Both gauges were within about 5deg of each other.
Nice!The antifreeze needs to be 'topped off' so it can touch the probe. As to accuracy, I also installed a 'pro' temp gauge that the probe screwed right into the radiator, which I assume is the location for an electric fan probe. Both gauges were within about 5deg of each other.
Elect fan probe location circled
Super!I will buy this Thermocap Radiator cap.Or.. You can just go down to the local auto store and buy a Mr Gasket Thermocap Radiator cap for $30US
