Not spun but some pretty ugly scarring. The thrust bearing was the worst. Only the #5 oil pump main mount cap and block side weren't damaged. The others a bit less than the thrust bearing. Rods didn't look much better, well quite a bit better than the thrust but damaged none the less. I asked to have the mains lined but said it was okay. The crank is the original, I asked for a new one too...didn't get it. I could hear a dull faint thump before rebuild...suspected the crank...said it was good. Now it's getting a new forged piece with Cleavite 77 H's...though people tell me Kings are the best???Can you say "spun main" bearing.
Edit; I'm quite surprised at the amount of damage compared to the noise it was making. It was more of a light tick. I thought I wiped my cam but no. It sounded more like the first time when a wrist pin started making noise.
