if he keeps the OEM wiring to his lights and splices in the EZ harness (which has directional and hazard flasher built in) correctly then I would think he can use a simple on/off toggle, no? The pull/push switch on the side of the steering column is nothing special IIRC.It was a special switch. Four terminal --when off, all 4 were isolated, when on, all 4 are connected together
You wire up a hazard flasher to constant hot power and feed that to one terminal of the switch
You connect one switch terminal and branch into the brake like switch output (to the TS switch)
You connect one terminal to the front left signal lamp wire
You connect the last terminal to the front right signal lamp were
So "when on" the lamp connects flasher output to the brake line going into the TS switch and to the left and the right front lamps.
You used to be able to buy "add on" hazard switches which usually were unitized with a flasher attached
21 fuse mini so it has a hazard wirevery basic - replace fan in image with hazard ~ don't use a momentary switch, you want a stays on/off
Which EZ harness are you using?
maybe hook up one light and get it working.. go from there21 fuse mini so it has a hazard wire
i will try this
That is designed to feed the hazard flasher which on a locking column car simply ties into the hazard flasher wire into the TS switch. I'm guessing there's a socket in your fuse panel?? for both the turn and hazard flasher?21 fuse mini so it has a hazard wire
i will try this
