First build
Discussion in 'Small Block Mopar Engine' started by John Ayers, Jan 12, 2018.
  1. John Ayers
    John Ayers SecondCuda705
    6
    0
    Dec 21, 2017
    Mahomet Il.
    Local Time:
    1:34 AM
    I bought a 1965 Barracuda Formula S. I found out that both heads have cracks. I was told that these can be pinned. The cracks are near the water jacket and not around the compression area.
    Has anyone repaired these heads and had success, I'm concerned?
    I was told that 318 ci and 340 ci heads will fit on the 273 ci block, is this a fact?
    I was really hoping that I could keep this vehicle stock but have a limited budget. Any suggestions?
    secondCuda705
  2. dart_68
    dart_68 Well-Known Member
    269
    124
    May 25, 2017
    Lakewood, CO
    Local Time:
    12:34 AM
    It might be cheaper, and better, to just get another set of undamaged heads. The regular 318/340/360 heads will bolt on but there may be valve clearance issues.
  3. roccodart440
    roccodart440 Well-Known Member
    4,257
    3402
    Apr 19, 2010
    Local Time:
    2:34 AM
    I had much better luck when mine were repaired with epoxy. The pinning kept leaking and leaking and leaking.
  4. 273
    273 Well-Known Member
    2,606
    452
    May 14, 2012
    Ontario
    Local Time:
    2:34 AM
    318 and 273 are the same head.
    340/360 and magnum valves are to large.
    • Agree Agree x 1
    • John Ayers
      6
      0
      Dec 21, 2017
      Mahomet Il.
      Local Time:
      1:34 AM
      I've been looking for some used 273 heads. Any suggestions on where to look?
      Also need a cam. any recommendations on this?
    • DesertRat
      DesertRat I don't care it's all psychobabble rap to me. FABO Gold Member
      2,277
      947
      Jan 22, 2005
      Moses Lake, Washington
      View My Photos
      Local Time:
      11:34 PM
      Be aware of intake manifold bolt angle change between 66 and 67-later heads. You should be able to find a set of 273 heads on this site. Put a request on the parts wanted forum.
      • Agree Agree x 2
      • dart_68
        269
        124
        May 25, 2017
        Lakewood, CO
        Local Time:
        12:34 AM
        If you can't find any 273 heads a set of 318 ones should work. But I would defer to others on this site for their better expertise as to exactly which heads will work best.
      • AJ/FormS
        AJ/FormS 367 FormS clone 3.09-1.92-1.40-1.09-.78od 3.55s
        11,406
        1991
        Jan 19, 2014
        Southern Manitoba,Canada Mosquito-land,900ft
        View My Photos
        Local Time:
        1:34 AM
        Yeah but the later 318 heads are open chamber, you sure don't want those,lol.
      • Max1196
        Max1196 Well-Known Member
        292
        111
        May 12, 2016
        Swift Current SK
        Local Time:
        1:34 AM
        Show us your crack! Take a picture, maybe it can be fixed.
        • Like Like x 1
        • cosgig
          cosgig MoBro Inc. FABO Gold Member
          10,071
          2188
          Jul 20, 2008
          Pinckney, Michigan
          View My Photos
          Local Time:
          1:34 AM
          I have many sets of 273 heads for you, and may have the perfect set! They're 65 heads, have been stripped and cleaned and can come with all of the valves and springs and other items that were removed! Best of all, they'll be cheap, because shipping will be a big factor here! I live in Michigan, near Ann Arbor if you live close by! Message me and we can talk about getting you what you need!
          • Like Like x 3
          • 66fyssh
            66fyssh Don't Stop Believin' FABO Gold Member
            2,933
            835
            Jun 22, 2013
            Rome, GA
            View My Photos
            Local Time:
            2:34 AM
            cosgig won't steer you wrong. He's one of the best.
          • 318willrun
            318willrun Stomper 4x4... we kept energizer in business FABO Gold Member
            5,145
            2329
            Sep 13, 2013
            I'm here
            Local Time:
            1:34 AM
            I have a '65 273. I live in the NW corner of IL. I would sell you just the heads, or the whole motor. PM me if your interested, thanks.
          • rumblefish360
            rumblefish360 so close yet so far away
            29,574
            2559
            Jun 21, 2005
            New York, on a Island
            View My Photos
            Local Time:
            2:34 AM
            Problem solved below. Good man below.
            Just for your information;
            The first 2 years of the small block have smaller bolts installed at a different angle. IF you use a newer head, you’ll need a newer intake or grind the old intake bolt boss to work.
            The small bore of the 273 limits valve size so a stock 318 valve will fit inside. A 360 or 340 intake valve, 1.88 - 2.02 respectively) will not fit.
          • John Ayers
            6
            0
            Dec 21, 2017
            Mahomet Il.
            Local Time:
            1:34 AM
            I tried to send a response but I'm new to this so if you get something twice, forgive.
            I live about 280 mile south of Ann Arbor. A friend found a set of head off of a '69 273. According to others on this site I would need to get the intake for these. So saying that it might be better if you and I can work something out.
            Let me know if you received my message. I'm trying to navigate this site and I'm not too good at it yet.
            @cosgig
          • Max1196
            292
            111
            May 12, 2016
            Swift Current SK
            Local Time:
            1:34 AM
            These cracks, are they to the outside of the heads. Why I ask is .did this freeze and crack, maybe check the water jacket sides of the block too.
            • Like Like x 1
            • John Ayers
              6
              0
              Dec 21, 2017
              Mahomet Il.
              Local Time:
              1:34 AM
              The heads are at a machine shop at this time. He said that the cracks were in both heads by the water jacket. The thing is that I didn't have any coolant in the oil when I drained it and it didn't seem to be coming out of the exhaust when I ran it before tear down. I will call him tomorrow and see if he will send me a picture to post.
              Can someone tell me how to post a PM on this site. I'm old but new at this. Thanks!
            • rumblefish360
              29,574
              2559
              Jun 21, 2005
              View My Photos
              Local Time:
              2:34 AM
              Simple, the PM is now known as “Start a Conversation”.
              Click on the screen name of the person you want to start a conversation with which is private between you both, or more if you choose & just follow along.
            • John Ayers
              6
              0
              Dec 21, 2017
              Mahomet Il.
              Local Time:
              1:34 AM
            • John Ayers
              6
              0
              Dec 21, 2017
              Mahomet Il.
              Local Time:
              1:34 AM
              Thanks for your help. I'll get there sooner or later.
            • rumblefish360
              29,574
              2559
              Jun 21, 2005
              View My Photos
              Local Time:
              2:34 AM
              Your welcome.
              When you hit the reply button, just wait for the quote to come up and then comment above or below the quote tags that look like —-> [ QUOTE ]
              Then you won’t have double posts. ;)
            • harrisonm
              harrisonm Well-Known Member
              1,411
              636
              Jan 16, 2005
              Topeka, KS
              Local Time:
              7:34 AM
              Dude, I just laughed outloud when I read this. It just struck my funny bone.
