67dodgedartconv
Can anyone tell me if a GM hei ignition module has to be grounded to work? Using it with a mopar electronic distributor on a 67 dart. Thanks.
Would I be able to get a good enough ground by using an alligator clip jumper from the module to a ground just to test it enough to see if it works?I think it does. Through the mounting screws.
