Grant classic steering wheel
Eric Pearson
73purpule duster
Houston Texas
I recently installed a Grant classic 3 bolt steering wheel in the Duster. It’s the replica tuff wheel. The only problem is that when I turn the wheel I hit the turn signal lever. Is there a spacer available for the 3 bolt wheels? Thanks
I eventually found and used a factory tuff wheel spacer/adapter. If your grant wheel is like mine it has the holes for the factory piece. When using the grant adapter I had cut down the turn signal stalk.
Pull the turn signal lever out and bend it at the base. After a trial fit or two, it'll be better than new, cuz' it's bent just for you!
Thanks everyone for the advice. I happen to have a spare turn signal arm that I bent. Will hopefully put it on tomorrow
