Guess on gears in a '74 318 Duster with 8-1/4 rear
Discussion in 'Transmission and Drivetrain Tech' started by DusterDaddy, Sep 12, 2017.
  1. DusterDaddy
    DusterDaddy sledgehammer mechanic FABO Gold Member
    2,032
    943
    Apr 21, 2011
    Holmdel, NJ
    View My Photos
    Local Time:
    12:42 PM
    If you had to guess, what gears are in the bone stock rear in my 74 Duster?
    The car is a factory 318/904 car with a fresh mild build 318 and a stock 904 cleaned up with a shift kit in it.
    Sadly there was nonfender tag and the mice shredded the build sheet under the back seat.
    Trans has the stock Mopar high stall converter in it. Have not really driven the car on the street other than a spin around the block yet but I am getting close to that point. I'm wondering how it will behave...
  2. 540slant6
    540slant6 Mopar SB Ripper
    517
    33
    May 21, 2015
    Berryville, VA
    Local Time:
    11:42 AM
    Probably 2.76 or 2.94. Best case would be a 3.23 unless someone special ordered 3.55's.
  3. 451Cuda
    451Cuda Well-Known Member
    1,552
    230
    Nov 19, 2008
    Lincoln, Nebraska
    Local Time:
    11:42 AM
    Probably 2.94
  4. oldkimmer
    oldkimmer Well-Known Member
    8,605
    483
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    11:42 AM
    A couple that I had with 318s had 2.71s. Kim
    • Thanks! Thanks! x 1
    • 451Cuda
      1,552
      230
      Nov 19, 2008
      Lincoln, Nebraska
      Local Time:
      11:42 AM
      If you still have it on the lift, just mark the inside of right rear tire and a point on the pinion yoke, rotate tire exactly once and count revolutions of yoke.
      • Like Like x 1
      • Agree Agree x 1
      • DusterDaddy
        2,032
        943
        Apr 21, 2011
        Holmdel, NJ
        View My Photos
        Local Time:
        12:42 PM
        A friend advised I do the same. She is home now, but easy enough to jack her up. i could just put the trans in neutral and count the yoke revs with on full turn of the wheel right?
        There are many mysteries within this nice little 318 I bought carb to pan. The builder is unknown but it has a purple cam with a .480 lift. That all I know about the cam. The motor lopes really nice at idle. The seller of the motor suggested I stay with the stock "high stall" torque converter so I did.
        The seller was a speed shop owner who acquired the motor, which was not fired until it was in my car, when he swapped it out of a Demon that one of his clients bought from a divorce situation. His shop kept the 318 as part of the compensation.
        It has Keith Black pistons and the interesting thing is the heads are stock 74 318 heads but they have the 360 1.88/1.60 valves in them and they are very nicely gasket matched and blended.
        It has a performer
        Intake and a 600 cam Holley street avenger on with with 340 hi-po exhaust manifolds and straight 2-1/2 duals.
        I look at it this way. I like that my car left the factory a 318/904 car and it still is a 318/904 car. It just has some
        Performance enhancements.
        My 69 318 bone stock 2 bbl barracuda would blow the doors off most anything off the line. So this thing should be a hoot to cruise around in....
      • H22A4
        H22A4 Well-Known Member
        1,194
        179
        Aug 4, 2006
        YVR
        View My Photos
        Local Time:
        9:42 AM
        I'd guess 2.94 but if you might be super lucky and have 3.21's. 3.23 gears came in the 8 3/4, never in the 8 1/4.
      • SGBARRACUDA
        SGBARRACUDA ROY FABO Gold Member
        11,384
        1812
        Dec 7, 2006
        PLANT CITY FL.
        Local Time:
        12:42 PM
        I'll guess 2.45's
        • Agree Agree x 1
        • SGBARRACUDA
          11,384
          1812
          Dec 7, 2006
          PLANT CITY FL.
          Local Time:
          12:42 PM
          Why not drop the rear cover and get right to the bottom of this mystery?
        • forphorty
          forphorty Well-Known Member
          496
          104
          Jan 19, 2006
          Local Time:
          11:42 AM
          I've had two A body 8.25s and they were both 2.45s. Maybe I was just unlucky.
        • 318willrun
          318willrun Stomper 4x4... we kept energizer in business FABO Gold Member
          5,134
          2324
          Sep 13, 2013
          I'm here
          Local Time:
          11:42 AM
          my '76 8 1/4 has 2.45
        • 66jim
          66jim Well-Known Member
          106
          55
          Dec 11, 2007
          Local Time:
          12:42 PM
          Had a 73 Dart Sport 318 904 I bought for he 8 1/4 from a local junkman, I wanted it to have 2.71 but to
          my surprise it was 3.21.
          • Like Like x 1
          • halifaxhops
            halifaxhops 1st instigator, Wives hate me everywhere! FABO Gold Member
            36,881
            8032
            Jan 20, 2014
            CENTRURAL, PA
            View My Photos
            Local Time:
            1:42 PM
            I had 3.21 in a 74 dart but it also has the tow package.
            • Like Like x 1
            • thesiren74
              thesiren74 Well-Known Member
              407
              79
              Feb 23, 2014
              kenosha,wi
              Local Time:
              11:42 AM
              Mine had 2.45s open.
            • DusterDaddy
              2,032
              943
              Apr 21, 2011
              Holmdel, NJ
              View My Photos
              Local Time:
              12:42 PM
              It would be like hitting the lottery if the gears are 3.21
            • DusterDaddy
              2,032
              943
              Apr 21, 2011
              Holmdel, NJ
              View My Photos
              Local Time:
              12:42 PM
              Cause whatever they are they are for now. Ill do 451cuda's test and get an idea of what I have for now..
            • Dartswinger70
              Dartswinger70 Well-Known Member
              955
              207
              Sep 20, 2005
              A train bound for nowhere
              View My Photos
              Local Time:
              12:42 PM
              I think you can mark the driveshaft with chalk and count how many times it "goes around" to one turn of the tire or vice versa.
              • Like Like x 1
              • DusterDaddy
                2,032
                943
                Apr 21, 2011
                Holmdel, NJ
                View My Photos
                Local Time:
                12:42 PM
                This is friggin bizarre!
                Jacked up the rear, car in neutral, rotated right rear wheel 1 full revolution. Driveshaft turned 1-1/8 full rotation.
                WTF?
              • SGBARRACUDA
                11,384
                1812
                Dec 7, 2006
                PLANT CITY FL.
                Local Time:
                12:42 PM
                That is because your rear end is a open differential. That method works on SG rears. What you are encountering is the spider gears turning.
                • Agree Agree x 1
                • DusterDaddy
                  2,032
                  943
                  Apr 21, 2011
                  Holmdel, NJ
                  View My Photos
                  Local Time:
                  12:42 PM
                  I find new ways to embarrass myself each day...
                  Well over the winter we will need to get us some gears...
                • 318willrun
                  5,134
                  2324
                  Sep 13, 2013
                  I'm here
                  Local Time:
                  11:42 AM
                  Ummm.... you could just pop the back cover off and read it.... :)
                  • Like Like x 1
                  • TrailBeast
                    TrailBeast Slightly Twisted Member
                    17,109
                    3310
                    Mar 11, 2011
                    Arizona
                    View My Photos
                    Local Time:
                    10:42 AM
                    Taller gears ain't all bad either if you have the torque to pull em.
                    • Like Like x 1
                    • DusterDaddy
                      2,032
                      943
                      Apr 21, 2011
                      Holmdel, NJ
                      View My Photos
                      Local Time:
                      12:42 PM
                      It stays as is for now. I'll take the cover off in January. lol
                      My car needs plenty of other things done before I take a perfectly working resr and give it a makeover.
                    • DusterDaddy
                      2,032
                      943
                      Apr 21, 2011
                      Holmdel, NJ
                      View My Photos
                      Local Time:
                      12:42 PM
                      You're not the first guy to say that Trailbeast.
                      The whole project has been an adventure.
                      The last major thing left is to reset timing after discovering a leaky brake booster then I'll drive it a bit and go from there.
                      Ignorance, desire and determination are a productive combination, although I'm at this thing for nearly six years....
                    • TrailBeast
                      17,109
                      3310
                      Mar 11, 2011
                      Arizona
                      View My Photos
                      Local Time:
                      10:42 AM
                      I hear ya, as my car was almost in that condition when I bought it and drove it home 150 miles without knowing anything about it.
                      I did notice it shifted from 1st straight to third right away, and that almost literally everything was either loose or broken.
                      Heck after I got the car home I found out all the spark plugs were only finger tight.:D
