I have an ATI super damper with a SBC pulley bolt pattern. It works great!...but the down side to using the SBC pulleys is you end up covering up the balancer bolt (for rotating the engine over by hand)
the up side is you have a VERY large variety of pulleys you can use that are CHEAP
Down side again, I still had to shim the pulley I got to make it line up with the water pump and alternator. You can order it with the Mopar pulley bolt pattern too if you like.
One other plus is it is rebuild able. When I built my stroker motor I used the ATI balancer from my 360 (cast crank external balance), sent it to ATI and they converted it to internal balance (for my forged crank) for ~ 50 bucks. I had used that balancer on the 360 for ~ 7 years and ATI said the balancer was still in great shape, but I had them service it anyway since it was apart (why not).
Bottom line, the ATI should be the last balancer you ever have to buy if you stay small block
and no, Im not an ATI salesman...I just sound like one :toothy10:.
