Hi,
I have a problem with my rebuilt '88 318 engine, head gaskets leak. Both of them has got a tiny leak of coolant creeping out between block and cylinder head below the headers. I also seem to get coolant in the engine oil. I have not re-torqued these head gaskets.
I am now using the P4120094 thin head gaskets, and OEM/untouched block deck surface and Edelbrock 60779 cylinder heads.
I have an average deck clearance at .012", but because of one of the cylinder banks not being level/square the deepest piston is .015" in the hole.
Now these thin head gaskets doesn't seem to seal very well?
I now have two options:
1) Replace with new set of thin head gaskets at .026" thickness (coated with Hylomar). .041" quench, 9.7 SCR and 8.88 DCR.
2) Use the Fel-Pro 1008 at .039" thickness. .054" quench, 9.37 SCR and 8.59 DCR.
This engine will use 91 octane pump fuel.
So what do you think?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
