I found the spring and retainer kit 73949K1 for $30 more than the springs. I will be going that route.
I went with the Hughes 1110 springs but bought them thru MagnumMopar. I already have new correct Hughes retainers and keepers to go with them.
Here are the specs for the both sets of springs.
MagnumMopar/Hughes 1110 Single spring spec
120# @ 1.660' INSTALLED 310# @ .550' LIFT
Installed Height/Seat load: 1.660"--120#
Pressure @ .450" lift: 280#
Pressure @ .500" lift: 300#
Pressure @ .550" lift: 310# @1.110"
Coil Bind: .620" lift
Outer Spring ID/OD: 1.033"/1.440"
Type of Spring: Single w/ damper
Lunati Spring Part Number73949LUN spec
Type: Dual w/damper
Outside Diameter of
Outer Spring (in)1.440 in.
Coil Bind Height (in)0.950 in./.700" lift
Damper Spring Included: Yes
Spring Rate (lbs/in)363 lbs./in.
Inside Diameter of Outer Spring (in)1.096 in.
Inside Diameter of Inner Spring (in)0.745 in.
As you can see they are almost identical other then one is a single w/damper and the other is a dual with damper that requires machine work to fit.
I've contacted Lunati and was told the #1110 springs are fine for use with there cams they recommend the 73949LUN springs for up to .535" of lift.
