Headers
gnr
Member
Suggestions on what headers to use on my 72 duster. Has a 318 and I am changing heads to 360 heads. What's the best header as far as easy install or should I get a descent set of each manifolds. Manifold in it now are 318 two barrel so ports are tiny compared to 360 four barrel
You will lose a LOT of compression putting 360 heads on a 318, FWIW.
yep!
As far as headers a lot of guys have used and liked Doug's headers. The cheap ones put 3 tubes under the tie rod linkage prone to getting banged up.
I just installed Doug's D453 on my 318....not too bad at all.
I'd go with Doug's again.
Jeff
IF you do exhaust manifolds, driver side 340 & early truck Magnum passenger side. (2-1/4)
Dougs is an excellent choice header wise.
Wow I guess I better do some research before using 360 heads. Thans
