Captainkirk
Old School Mopar Warrior
I've got an 8-3/4 diff in my Duster 340 4-speed, always assumed it's a 3.91 Sure grip, but how can I positively ID it? Thanks in advance!
What is the cam size and tire size? Then I'll feel you my answer.
3.55
3.91 = in town/track fun, 2800rpm at 55
3.55 = good all around choice for a driver, 2200rpm at 55
Just ball park figures with no overdrive.
Tires=14
Cam, haven't chosen yet but likely will be close to .475 lift 290 duration
OK, determined the pumpkin out of The Duke is a Sure Grip 3.55. Pretty sure the one out of the long-departed Li'l Red Minx is a 3.91....it's very close to 4:1 rotation. So next question: Which would you prefer to run with 340 and A833 4-speed?
Is that cam spec duration @ .050 or advertised and by whom is it made by. Because advertised duration specs differ greatly between manufacturers.Tires=14
I think he was looking for outside tire diameter, not what size wheels you have. A 28" tall tire versus a 26" tall tire will make quite a difference.
Your wheels are 14 inch. Now what about your tires? Wheel size is useless! Tire size is everything else!
