DragginMAster
Question number one:
The mechanics who worked on my car said I have my front spindles on backwards. they are the disc brake spindles off a 74 dart. are the calipers supposed to be in the front or the back?
is this different than if they were 68 dart disc spindles?
I cannot mount my power steering pump on my car due to interference with the motor mount.
the pump is off a 78ish Cordoba, I have the newer style radiator / water pump on my car which necessitates using that style of power steering pump. Is it ok to slice off some of the motor mount with say an angle grinder to make enough clearance for the pump to be moved into position?
anyone ever hear of or actually perform the task of spraying used motor oil on the underside of your car instead of pricier products in order to fight/prevent corrosion from road salt and other enemies of cars?
anyone know where I can get an S link for a Carter 625 CFM 4 barrel carb that connects to the accelerator pump? And is anyone amazed my car runs without the accelerator pump hooked up?
that is all for now.
