famous bob
mopar misfit
--------------LOL-----Beats the **** outta me.
(Rodney King's quote when asked his opinion of the LA Police Department.)
My LA360 plow truck runs great with the 318 Performer on it. It's more about where you want the power. I don't ever go over 4200, and most stuff is 3500 or so max, with cruise at 2K-2400. It's been on there 10 years of more now. I'd say if you're not normally running full throttle over 4k, it's fine and it's all in your head. Up to you. SOme people get bugged by stiff like that.
I keep coming back to a couple questions. If this was my boggle, would I be satisfied with the 2176 reworked, even if I thought I could feel the improvement on the street, or at the strip for that matter? Would I constantly wonder if the bigger volume of the air gap would be even a little better? What if I cleaned up the air gap before I put it on; how much more would I get? Screw that! I'll get the air gap so these questions don't keep me up at night.
get the air gap.it was a large improvement over my ld340, contrary to popular opinion!now to try strip dominator with tq superquad
I also made this swap. The LD-340 is capable and not worth the current intake prices to swap IMO, but you will notice an improvement.where did you get the results showing the air gap as an improvement over the LD340?
Stock cast intakes are used successfully on small blocks running in the 10's.
I would recommend the regular RPM for a street car but you're in Arizona so cold temps probably aren't that big of an issue lol. Air-Gap FTW, I ran one on my 360 with Magnum heads that had a slightly smaller cam than yours (213/220* @ .050" on a 114) and it was a torque monster, had a stock ~2100-stall converter with 2.94 gears and still shot off the line pretty well. Got pretty good gas mileage too, like 19-20 on the highway... initially ran a 625 cfm Carter AFB then switched to a 750 cfm Street Demon (the "modern TQ"-looking carb).
The ports on the RPM will better match your heads. It's not like you have 318 2-barrel heads on there.Given what you have, and where you are, I think you are asking for more issues by changing to a larger port intake. Again - choice is yours.
I am running the Magnum #7577 RPM Air-gap with mild cam and OE replacement heads and it's not lacking anything anywhere. Not trying to argue just thought you'd like to hear from somebody actually running something like what you are looking at.I rarely tell people what I am doing with my car, and mostly because I don't need extra opinions but this subject is something others may like to know so here we are.
When I built my drivetrain I had a limited amount of money to work with so I bought a totally stock Magnum with approx. 96k on it.
I knew I was replacing the heads and cam right away, and used the Engine quest CH318B (LA intake drilled) heads with 1.92 intake valves, good positive sealing stem seals and the Hughes 1110 spring kit with the extra clearance retainers.
I wasn't going for all out horse power, but a nice reliable daily driver.
The cam is 214/[email protected] .512 lift on a 110
I used the Edelbrock 600 cfm carb and 2176 318/360 Performer intake I had on my 318.
Now awhile later I am going back over a few things I knew were not quite optimal even just for a daily driver.
Even though the motor runs really nice and has been super reliable, I have to somewhat laugh about the intake to heads ports situation.
The EQ heads intake ports are around 1/4 inch larger all the way around than the 2176 ports are, and though I know it would be way worse if it were the other way around it seems I can't stop thinking about doing something about it, as I can't help thinking the intake charge is probably slowing down right where it probably shouldn't for the mid RPM torque the cam is ground for.
Any thoughts on if a different intake would be better for ft lbs but still keep everything under thee hood and keep the dual plane street manners?
It sure wouldn't hurt anything to have more power available, but would a different intake make that much difference for daily driving.
I can use the excuse that the 2176 would better suit the Wifes stock 318 with a 1968 340 grind cam.
