For a 340 with Eddy RPM heads which would be a better intake? Eddy Preformer RPM or a Weiand 8007? Have not picked a cam.
Many thanks.
Many thanks.
Somehow, I knew you'd say that. And I agree! lolAgree, pretty close performance wise. I would use the Weiand because you can bolt on a good carb direct, like a TQ.
Weiand Action Plus (#8007) | |
Scatter | 242.9 - 274.3 cfm |
Spread | 31.4 cfm |
Average | 258.6 cfm |
Edelbrock RPM | |
Scatter | 248.6 - 264.9 cfm |
Spread | 16.3 cfm |
Average | 255.9 cfm |
That Performer RPM looks suspiciously like a LD manifold.For a 340 with Eddy RPM heads which would be a better intake? Eddy Preformer RPM or a Weiand 8007? Have not picked a cam.
Many thanks.
Edelbrock LD-340 Shallow Port Match | |
Scatter | 279.2 - 314.1 cfm |
Spread | 35.0 cfm |
Average | 299.7 cfm |
Test note:This was the best 4BBL intake for small-block Mopars for many years. This particular manifold (borrowed for testing) had a port match that was only -inch deep. The flow is impressive for an ancient dual-plane, but the flow bench does not always tell the entire story. |
Edelbrock RPM | |
Spread | 16.3 cfm |
Test note:This intake has an excellent and well-deserved reputation and has taken the place of the LD-340. This is one of those cases where the flow bench does not tell the whole story. This manifold did not flow as much as the LD-340, but it will produce more power. Why? Look at the manifold intake runners. Notice how the port shape and runner arrangement has changed from the older LD-340 to the RPM. The runner lengths are shorter and the cross-sectional areas are more consistent from the plenum to the head. Lots of flow work and testing went into the newer intake design which paid off in horsepower. |
The runners in the Performer are thinner width wise. I wonder if they are taller though compared to the LD340. Improved velocity? Just spit ballin' here.From the article I linked above.
Show All
Edelbrock LD-340 Shallow Port MatchScatter 279.2 - 314.1 cfm Spread 35.0 cfm Average 299.7 cfm Test note:This was the best 4BBL intake for small-block Mopars for many years. This particular manifold (borrowed for testing) had a port match that was only -inch deep. The flow is impressive for an ancient dual-plane, but the flow bench does not always tell the entire story.
Edelbrock RPMScatter 248.6 - 264.9 cfm Spread 16.3 cfm Average 255.9 cfm Test note:This intake has an excellent and well-deserved reputation and has taken the place of the LD-340. This is one of those cases where the flow bench does not tell the whole story. This manifold did not flow as much as the LD-340, but it will produce more power. Why? Look at the manifold intake runners. Notice how the port shape and runner arrangement has changed from the older LD-340 to the RPM. The runner lengths are shorter and the cross-sectional areas are more consistent from the plenum to the head. Lots of flow work and testing went into the newer intake design which paid off in horsepower.
Tom
Fresh boat motor? Better make sure it's not a reverse rotation engine, or it won't matter which manifold you pick. But you will have the fastest car in town- in reverse!Wow, a lot of real good info and points. Many thanks. I'm a Holley guy so I think the RPM is the one for me plus as stated it is made for these heads.
Just starting a plan and trying to use what I have which is a fresh 340 boat motor, the set of RPM heads and the two manifolds. Don't even know which car it is going in.
Thanks again guys.![]()
Yup I checked that first. It's standard rotation. It's a 1974 Super Bee III 340. Small cam and small heads.Fresh boat motor? Better make sure it's not a reverse rotation engine, or it won't matter which manifold you pick. But you will have the fastest car in town- in reverse!![]()
This might be problem; depending on your expectations for the 340.Well my county goes from 4300ft. to 10800ft. so that is a big variable. Not stroking it. Would be a street car.
