ham_r_down01
Is Freak Nasty
I have 3 different intakes,
1. Edelbrock Torker II low rise single plane
2. Holley Strip Dominator single plane
3. Knock off Edelbrock Air Gap dual plane
69 340, Stock bore/compression, Mp purple shaft .484/.484, ported X heads
904 trans, A and A manual valve body, 2200ish? mopar converter
8 3/4 rear end 4.10 ratio with a sure grip
The car is a 69 Dart as of now it runs a traction limited 13.06 @ 105
I have these intakes, the Torker (650 DP) is on the car now because thats the one i wanted to use at the time. I have been thinking about switching it up a little.... Intake, carb or both???
Comments?
Comments?
