I was given a blown up 360 for parts. I took it apart to salvage the timing cover, heads etc. I got looking at the block and other than a 3/8" chunk out of the bottom of the #2 bore on the inside it looks good. There was a major catastrophe on #1/2 rod journal. I cant take a photo without removing the crank. Just wondering if this block is possibly usable or should I send it to scrap? Is that damage to the bore a deal breaker? Its definitely not so far into the bore that the rings will be affected.
Cley
Cley
