[WANTED] looking for 6 pack setup for a 340
cudamanbob
illinois
I am looking for a complete 6 -pack setup for my 70 340 motor . air cleaner to the intake with all linkages . if anybody has this please let me know . looking to buy . thank you
New? Used? Only parts or piece?
Type in Manciniracing.com for starters. Keep searching the web for the best deal on new ones. I took approx. A year to put mine together part by part. It was a serious money saver IF you can wait it out. I kept searching putting in the part numbers for each part. I managed to save just about half the cost. Some places mis price or jus dump there stock.
I got all my carbs at 1/2 price.
I am in no hurry about doing my motor . I am turning my 340 into a 416 motor . the cylinders were scared so we had to bore it . just startin to get parts together for it . thanks for the info , I can use it .
You can put a functional six pack together for pocket change if you do a little junkyard scrounging. Ford used 2300 series Holley's on various car and truck applications for years. Base plate is the same as the 6Bbl , difference is in the air cleaner mounting surface. Cut off the back to make a D shaped top, and you've got a $10 carb. Toss in a universal linkage kit and you can do an entire set-up for around $300.
I have a total of $1,600 in mine i mean total that's with t-stat, gaskets,air cleaner and filter, manifold water fittings,intake carbs everything! i would look for the 4782/4783 Holleys they flow around a true 1150 where the stock ones flow about 950cfm.
