modified intake
dirty white boy
50 yr old Juvenal delinquent
stoneville n.c.
any body ever try mod'in a stock intake for a holley 2280 carb? if so how did it work out? pro's con's???
Yes, it's been done. See the parallel 2bbl setup article. Photo documentation of a very well done such conversion is here. The 2280 is an OK carb especially if you find a brand new one. Same mount pad also accepts Carter BBD or Bendix Stromburg WW. You might want to consider modding the manifold for the larger mount pad of a Motorcraft 2100/2150; see this thread and this one. That would wind you up with a good-running setup and an appropriate air cleaner would be easy to find. Also see here and search this thread for "motorcraft" and/or "2100".
slantsixdan is the man! great info and exactly what i was looking for!! already got the 2280 on a 318 thats getting a upgrade! thanks for shearing your wisdom.
