About 600 miles on the engine. Running stock cooling system for 1973 Dodge Dart Sport 340 with what I believe the original radiator 26" with stock shroud and 18" 7-blade fan with thermal fan clutch 13lb cap and has A/C but not working at the moment. System has been flushed once during heater core replacement last year. Engine was installed late 2016. Timing is initial 12" with about 32" total. A/F set via drop rpm method with the highest vacuum 14". Idles at about 800-830 rpm and runs good otherwise, but seems to run hot in Sunday morning minimal traffic, 85-90 degrees. Seems to idle for 30 min. in driveway at about 205*
Here are the specs per my MRL build sheet:
Edelbrock 1406 600 CFM carb with step 23 setup
Airgap type dual plane intake
2.02 Intake valves
1.60 Exhaust valves
Iron stock heads
Stock 340 Exhaust Manifolds
FBO Ignition System with limiter plate and spring kit
Summit K50062 CAM 285/218 .480 lift 118 LSA 108ICL
Summit Racing® Cam Kits SUM-K50062
SBM Mopar water pump 58-184 6-blade 6 vanes
180* Mildon high flow thermostat
Turbo Action Torque Converter 17501 11" 2500 stall
Flex plate for external balance
3:23 Rear Gears
Coolant is 50/50 conventional green
Hood to radiator support seal is installed
Radiator hoses are new gates, but lower one does not have a spring in it.
Used ifrared temp reader and temp is about 13* difference from top of raditor by hose inlet to outlet.
This seems to run hot y/n? What are my options? Water Wetter?
Thanks.
Added Autometer electric gauge with it's own sender to work in conjunction with the stock gauge
2.02 Intake valves
1.60 Exhaust valves
Iron stock heads
3:23 Rear Gears
Thanks.
