What would be the biggest cfm 2v carb i can put on my 273 barracuda,would like something that wont bog down but also wont be a dud.Thanks for any info.:bootysha:
Bear in mind the Holley 2300 series (like the above mentioned 500 CFM unit) will not bolt to your factory manifold. Find a 2v carb form a 360, 361 or 383 and try it. Thats about as good as it gets.
you can put the 2v holley on the 2barl. intake i had one on a stock 2v 360 intake the 2v to 4v adapter works 20 bucks at the zone i know it says 2v to 4v but read apl. it works but i never could get my passing gear to work with that set up
